Creating double lines
Tool
Tool set
Shortcut
Double Line
Basic
Alt+2 (Windows)
Option+2 (Mac)
The Double Line tool creates a wide variety of constrained and unconstrained double lines. Set the width between the double lines, the offset from the cursor, and whether to create components between the double lines.
Mode
Description
Constrained
Constrains the line to be vertical, horizontal, and 30 degrees or 45 degrees from vertical or horizontal in any direction
Unconstrained
Draws the double lines at any angle.
Press and hold the Shift key to snap the line to predetermined angles.
Left Control Line
The cursor draws the left line
Center Control Line
Creates lines equidistant from the cursor
Right Control Line
The cursor draws the right line
Custom Control Line
Draws the line at an offset from the center of the two lines; specify an offset value in the preferences
Preferences
Opens the Double Line Preferences dialog box for specification of additional object parameters
Separation
The distance between the double lines; the value must be greater than zero
To create double lines:
Click the tool and mode.
Click the desired offset mode to specify the offset method.
Enter the distance between the double lines in the Separation field on the Tool bar.
Click Preferences to set other parameters.
Parameter
Description
Separation
Enter the distance between the double lines; same as the Separation field on the Tool bar
Control Offset
For Custom Control Line mode, enter the distance from center of the two lines, either positive or negative. The distance must be less than the Separation distance between the double lines.
Options
Create Lines
Creates parallel lines
Create Polygons
Creates a double-line polygon with closed ends
Create Lines and Polygons
Creates parallel lines with a polygon between them; the polygon has a line weight of zero
Components
Click to define components between the double lines; see Applying components between double lines.
Component fills are visible only for double lines created with Create Polygons or Create Lines and Polygons selected.
Click at the double line’s start point.
Click at the double line’s end point.
Creating single lines
Creating a break line
Displaying and reversing object direction
Marker attributes
